Gold Member Username: DeadrabitMarionville, MO Post Number: 1849 Registered: Jun-07 | not really but i am in the low 150s now. still have not had time to test eveything or test anything at all, i am just trying to finish the front so it looks nice and i can keep my car clean then ill test. i am getting 1st in my class now until this one dude replaces his subs he was getting 154 and blew them so i am on top for now. still saying ill be up between 155 and 160 after testing its just finding time to do all of that the back baffle is a good 5 inches thick not solid wood but braces sandwiched togather even if u all think my ideas are bad and it wont be loud or sound good or what ever u have to say it looks pretty nice |
Gold Member Username: Tatonka-[Team Audible Insanity]- Post Number: 2977 Registered: Mar-07 | They make black bondo? |
Gold Member Username: Drant19DUB-C, TX Post Number: 1744 Registered: Aug-07 | in the second pic...why are the AQ logos "QA"??? |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20579 Registered: Jun-06 | The pic has been reversed. |
Gold Member Username: Drant19DUB-C, TX Post Number: 1745 Registered: Aug-07 | dblk bought bootleg AQ subs... |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1853 Registered: Jun-07 | its bed liner, before that i mixed bondo and resin then my box was pink |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20580 Registered: Jun-06 | |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1854 Registered: Jun-07 | edit |
Gold Member Username: Snowball123West Allis, WI Post Number: 2820 Registered: Oct-07 | what's the top speed of the car now. 20 mph? |
Platinum Member Username: InsearchofbassPost Number: 11570 Registered: Jun-04 | Good luck man. You put alot of time and money into that. |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1859 Registered: Jun-07 | still getting 31mpg |
New member Username: SanniWaukegan, Illinois U.s.a Post Number: 7 Registered: Jun-09 | how much was those subs |
Platinum Member Username: Nyyfan13Northern VA Post Number: 11460 Registered: Jul-06 | Too much for you pal Sike, F and F took over there for a sec. Check Audioques website. www.audioque.com should be it lol. |
Bronze Member Username: SundownzMooresville, NC USA Post Number: 18 Registered: Nov-06 | Nice - how much power on tap ? |
Silver Member Username: WickedbassNashville, Tn Post Number: 650 Registered: Jan-08 | Two RD1750.1s I think. Could be wrong tho. |
Gold Member Username: Snowball123West Allis, WI Post Number: 2824 Registered: Oct-07 | At least this box looks better than the old one. You gonna take pictures of your scores next time? |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1860 Registered: Jun-07 | ya a pair of rd 1750s. i think i have a problem with one of them ill have to call steve ill take pix. don't expect anything to high. at least for now but i know u didn't expect me to even get over 130dbs so thats cool |
Gold Member Username: TejcurrentPost Number: 1819 Registered: Apr-07 | "I believe you will end up somewhere between 147 and 152, but what do I know? 160 and I'll send you $5" "I think you will have a lot of trouble getting over 53 without throwing a lot more power in there." |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1862 Registered: Jun-07 | haha. getting over 153 wont be hard. i tried tunning to the 1/4 wave and it didn't work at all. my hit note was 65Hz and it is louder when it is tuned lower... plus it doesn't sound like poo. after testing and some small changes we will see what i hit |
Gold Member Username: HdubbTeam Revolution Post Number: 4139 Registered: Nov-04 | wouldnt it make sense to use the 1/4 wave of the frequency your car resonates at? not just some random frequency |
Gold Member Username: Basebalz13Moneta, Va Usa Post Number: 1555 Registered: Aug-07 | yes but im sure he already knows that, he knows everything else already |
Bronze Member Username: LoudgangstaPost Number: 18 Registered: May-08 | nice looking setup you got there. |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1864 Registered: Jun-07 | "wouldnt it make sense to use the 1/4 wave of the frequency your car resonates at? not just some random frequency" that is what i did last week. it was not loudest using it though. it was kinda weird. has any one else used 1/4 wave and found it to gain spl? my hit note was 2Hz high . i have not had time to mess with it as much as i would like but 67 should be 1/4 from the front dash to the wall. its almost like 1/4 made it worse but idk! i can't say anything for sure because ihave not tested many other Hz yet. but tuned to 40Hz was louder than 69Hz and 1/4 is 67 as i measured |
Bronze Member Username: SundownzMooresville, NC USA Post Number: 40 Registered: Nov-06 | With my current double woofer box in the Jeep I am louder tuned to 35 Hz than to 45 Hz... my actual vehicle peak is 53 Hz but this box peaks at 48 Hz regardless of what the math says the port is tuned to (I cut it down several times and tested). SPL can be weird |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1871 Registered: Jun-07 | ur right! i have seen people round of corners and it loose a few tenth of a dbs. this is y i think ill get such high numbers i don't mind taking the time and trying everything i can think of. jacob what do u have? |
Bronze Member Username: SundownzMooresville, NC USA Post Number: 45 Registered: Nov-06 | Honestly it looks pretty good - with more power I am sure it will keep climbing. You could try talking to Gary F on Team Sundown as well - his setup is doing great numbers with similar power : http://www.soundsolutionsaudio.com/forum/index.php?showtopic=28494 I, personally, don't have a whole lot of experience with wall setups but maybe he can help. |
