Silver Member Username: Purplehase_bongBC Canada Post Number: 335 Registered: Apr-04 | theres an amp locally i can get for dirt cheap. just wondering what you guys think and if i should buy it. specs are Output power (14.4V) : Class - D (MONO) Into 4 Ohms : 800W x 1 Into 2 Ohms : 1500W x 1 Into 1 Ohms : 2800W x 1 Linkable at 2 Ohms : 4800W x 1 Frequency Response : 20Hz ~ 330Hz S/N Ratio : > 90dB T.H.D : < 0.03 % Input Sense : 300mV - 8V Variable Bass Boost : 0~+18dB at 45Hz |
Gold Member Username: Drant19DUB-C, TX Post Number: 1750 Registered: Aug-07 | those number could be impressive or overrated...whats the actual amp model? (ie. Sundown 1000d, mmats 3500.05, etc.) |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1861 Registered: Jun-07 | what amp is it? |
Silver Member Username: Purplehase_bongBC Canada Post Number: 336 Registered: Apr-04 | sierra spl 4800.1 Monoblock D class http://www.sierracaraudio.com/2005_product_sra4800d.html |
Gold Member Username: Safe_crackerOnly Fcking H0M0S , Say WaterPolo! US Post Number: 4939 Registered: Jan-06 | A class D amp typically has a THD of around 1% the .03% THD gets me thinking... BS.. Polo. |
Gold Member Username: CarguyPost Number: 6960 Registered: Nov-04 | How much is the amp? If you go by the spec alone, they should be charging you $2000 - $3000. Don't get sold on numbers. Take a look at Pyramid amps. They will promise you the moon for $100. Read the fine print on their website. |
Silver Member Username: Purplehase_bongBC Canada Post Number: 337 Registered: Apr-04 | 275cad, warehouse lasts. I'm going to take a look tonight |
