New member Username: MikerandPost Number: 10 Registered: May-09 | Sorry guys I'm kinda new to this so I need some advice. If I got this amp... http://www.autoaccessorystore.com/home_n.asp?dir=detail&id=1881 and this sub.... http://www.sonicelectronix.com/item_10580_JBL+GT5-12.html Would this setup work??? Pros? Cons? Thanks! |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 7494 Registered: Mar-04 | Yes, if you at just looking for a little bass on a budget it will get the job done. And w/ that amp, you have room to upgrade to a pair of those JBL's later on. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10521 Registered: Jul-06 | That will work. Wont be real loud but it will work and thats decent equipment. |
