Silver Member Username: Armykyle1Ms Us Post Number: 634 Registered: Dec-08 | got the amp in, now I need a box, batts and wires lol. I really need some one to build me a box. I've messaged fisher a few times and no response. I'm wanting a triple chamber slot port, 1cube each @31hz. But if someone can talk me into a common chamber box I'll be down. 3 RL-i 10s. |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1055 Registered: Feb-07 | Nice amp. The nice thing about a common chamber is that it is easier to build less can go wrong with it. It is easier to wire all the subs up. And i believe you can get better spl results. Are you still not up to building a box yourself? If not i could probably build one for you. |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1056 Registered: Feb-07 | You can see some of my work at http://www.j-designs.org/viewtopic.php?f=10&t=268 |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2574 Registered: May-04 | Nice subs man! |
Silver Member Username: Armykyle1Ms Us Post Number: 635 Registered: Dec-08 | thank you man. I'll deff think about it matt, I would try to build one but I think it would be an epic failure. If I could get box plans I might. Yeah the common chamber would give better SPL, well for the most part, but I'm aiming more for SQ but with good out put lol. The guy at SS said I can got up to 2cubes each, but it wont have a good flat response. Just gotta keep the tuning below 33hz he said. But I think 1cube each is plenty good. |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1060 Registered: Feb-07 | That should be enough per sub. I could also do plans if you want. |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 4135 Registered: Nov-05 | what type of vehicle? |
Gold Member Username: Van_manBoston South, MA Post Number: 4859 Registered: Mar-06 | check this one.. |
Silver Member Username: Armykyle1Ms Us Post Number: 642 Registered: Dec-08 | that's too narrow for 3 10s lol, but that would work if it had some bracing. as long as the tuning is below 33hz |
Silver Member Username: WickedbassNashville, Tn Post Number: 636 Registered: Jan-08 | Very nice subs man! Be sure to post pics/vids when its all said and done. |
Platinum Member Username: Nyyfan13Northern VA Post Number: 11456 Registered: Jul-06 | Sweet subs Kyle. |
Silver Member Username: Armykyle1Ms Us Post Number: 646 Registered: Dec-08 | thank you guys, I will for sure. |
Gold Member Username: Van_manBoston South, MA Post Number: 4861 Registered: Mar-06 | this one workfor you? |
