Gold Member Username: Saqeeb9000Post Number: 5220 Registered: Oct-07 | i am going back home next month, i was wondering if i can buy ups from north america, basically what it does it its like power storage u can store power in it and u can use it once power is out, pls let me know thanks |
Gold Member Username: PlymouthCanada Post Number: 9677 Registered: Jan-08 | Sada You talk about Uninterruptible Power Supply or APC Do a search on google or yahoo and you will find it easily. |
Gold Member Username: Saqeeb9000Post Number: 5222 Registered: Oct-07 | ok thanks plymouth , i will try that |
Silver Member Username: BernardmiPost Number: 479 Registered: Dec-07 | I do not agree sada. A UPS is related to satellite. Matter of fact, it is a good idea to have one around as it does start automatically at the slightest power glitch in a matter of milliseconds and protects your equipment(s). Very practical to save PC's and expensive TV's during thunderstorms. Look at APC for those. They use common sealed lead acid batteries available everywhere. They are also the most reputable. The Back-UPS series. http://www.apc.com/products/family/index.cfm?id=21 Note the older APC series (in the steel boxes) are often available as second hands units. Just need to replace the battery inside. A good reputable battery store will recycle the old battery by the way. |
Gold Member Username: Saqeeb9000Post Number: 5223 Registered: Oct-07 | thanks outerlimit but most ups are 120 v back home power is 240 v . i called few companies and they said first of all they will not shipped outside of us because they have acid in it + i can't carry them with me on plane, and they are like 100lb weight,lol so i will see if i can find something like "solar power" |
Gold Member Username: SatgrlDil Mei DarD a Jaga ... Post Number: 1769 Registered: Oct-07 | lol yah u need that back there "home" where u from india or paki?happens in paki lol belive me |
Gold Member Username: RiconissanPost Number: 1188 Registered: Feb-09 | sada did you consider a donkey powered dish? |
Gold Member Username: Saqeeb9000Post Number: 5224 Registered: Oct-07 | pak elec is out for 8 hrs so i will take ups with me rico lol |
Silver Member Username: Rafiq128Post Number: 196 Registered: Feb-08 | You can buy it locally in Pakistan , They are available every where. no need to buy from here, its very common there, In lahore, Karachi and all the big cities this is availabale in Electronics markets. |
Bronze Member Username: Last_supperNazerith , Isreal Post Number: 38 Registered: May-09 | If you go to Lahore, bring a machine gun |
Gold Member Username: GregrafPost Number: 2961 Registered: Dec-07 | |
Gold Member Username: Saqeeb9000Post Number: 5225 Registered: Oct-07 | ok thanks bhatti |
Silver Member Username: AgfPost Number: 113 Registered: Aug-06 | Sada, You are better off getting it back home, first there will be some warrenty and secondly in case something goes wrong you can always get it fixed. All the best. Moreover its not worth getting it from North America, try online you may be able to ship it from the gulf states where the power is 220 to 240 |
Gold Member Username: RiconissanPost Number: 1194 Registered: Feb-09 | What gulf State is 240v? |
