Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10478 Registered: Jul-06 | So out of all the decent brands i've found a total of 2 HUs that do what i want. http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/DVD-Receiv ers/AVH-P5100DVD?tab=B This ones a flip out screen which i really like. But the cost is $500 plus $120 bluetooth adapter plus $50 new sirius adapter plus remote (not included) = about $700 total. More than I want to spend. http://mobile.jvc.com/product.jsp?modelId=MODL028484&pathId=133&page=2 This is the other option. Single din touch screen. $450 Bluetooth built in. Works with existing sirius adapter. Both have USB. I like the bigger screen on the pioneer but i don't like its price. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 3376 Registered: May-07 | I obviously like Pioneer better, but i wouldn't pay that much extra for just a DVD player... I guess it depends on how bad you want to watch sh1t while driving.. I couldn't see watching anything as loud as I play it, unless it is a musics video, but I don't need any distractions, as I am usually looking for cops with my finger on the ATT button on my remote. |
Gold Member Username: CtmikeCt. Post Number: 6712 Registered: Feb-06 | jvc. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 3378 Registered: May-07 | Ummmm excuse me sir, but you have heard of the pioneer rca/pico fuse problem, right? Alpine > Pioneer |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10484 Registered: Jul-06 | The JVC plays dvds also, has video in/out and all the same features. Not that I'll even use that though. RCA issue i've heard is fixed on the new ones but obviously id have to research that before i bought one. Difference is pretty much is the bigger screen worth $250 more. I'm thinking not. |
Silver Member Username: Armykyle1Ms Us Post Number: 610 Registered: Dec-08 | I like the JVC, it looks pretty damn clean. I've had a few JVCs and had pretty good luck |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10495 Registered: Jul-06 | I am really liking that JVC unit but i want to able to actually play with that touchscreen and see how the interface is before i buy it..... and theres no JVC dealers close to here. except best buy and they dont have it. |
Silver Member Username: TeamrevolutionATLANTA, GA USA Post Number: 636 Registered: May-07 | all new jvc arsenal peices use 5volt bur brown dac. Most likely a result from them merging with kenwood a while back. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10503 Registered: Jul-06 | My current JVC is an aresenal series. This new one is not but it does have the 5 volt outputs. |
Gold Member Username: Stateprop486Phnom Penh Cambodia Post Number: 1825 Registered: Jan-08 | jvc. im running a JVC KW-AVX810 7" Double Din and i absolutely love it. i never had a problem with it at all and ive been running it for like 5 months now. you can see a pic at my cardomain http://www.cardomain.com/ride/3327278 |
Gold Member Username: Van_manBoston South, MA Post Number: 4839 Registered: Mar-06 | "Most likely a result from them merging with kenwood a while back." Mite as well Look at some Excealons while your at it. The 09 models are pretty slick. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10506 Registered: Jul-06 | kenwood doesnt have anything that fits my needs/wants I'm really thinking about buying that JVC |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20546 Registered: Jun-06 | Execute and be done with it. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10513 Registered: Jul-06 | haha. if mark buys my amp i will. otherwise its waiting another pay cycle |
Gold Member Username: Snowball123West Allis, WI Post Number: 2797 Registered: Oct-07 | which amp of yours? |
