Choosing the right amp...need some help please.
Username: Mikerand
Post Number: 7
Sup guys, Im new to all of this so I need so help choosing the right amp for this subwoofer I am planning on getting.
I am going to be getting one of these.
http://www.sonicelectronix.com/item_10580_JBL+GT5-12.html
What amp would be good for this sub?
Preferably between 100-150$.
Username: Poprocks
Post Number: 191
OK since your sub is a single 4ohm and your on a budget. Get a 2 channel amp and bridge to 4ohm mono.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=41
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16916
And remember to build the box to your subs spec, it makes a world of difference.
Goodluck
Username: Mikerand
Post Number: 8
k thanks
