Kbox help indian channels
Username: Jballer
hi i got kbox k1 plus it was working fine with all the indian channels until like 2 days ago...i am getting channel 812 and 809 and sometimes 622 but other channels like b4u i get a black screen... the light on the hug is green...so wt can be wrong plzz help
Username: Saqeeb9000
Post Number: 4973
which dish?
Username: Pannu16
Post Number: 869
I am gonna change to 118.7 and 119 on one dish tomm...
Is Kbox working on Indian channels on IKS on 118.7...
Also if somebody can post settings for KBOX with one LNB for 118.7 and 119.. how wud it work coz LNB will have only one wire running to box and i want channels from 118.7 and 119.. so help me out with settings in receiver..
Username: Jballer
i have both dishes up 61.5 and 118.7
Username: Jballer
help any1
Username: Rafiq128
Post Number: 194
You can try
1. switch off receiver from back and wait 30 sec. and switch on ( Hard Reboot)
2. Do the same thing with Khub.
3. Try rescan all the channels again.
Hope this help.
Username: Kirankumar
NO Bashing
Post Number: 3136
channels working on 118, not on 61.5
with khub only
Username: Jballer
wt tp do i need to scan on 118 to get the channels?
Username: Jballer
i think i ve a figured out... it cud be cuz i dont ve 118 setup properly...can any1 tell me w tps i need to scan cuz wid autoscan i am not picking up all the channels.
NO Bashing
Post Number: 3138
to get 118, you will need at least a 30" dish and special 119/118 lnb
you will remove your existing 119 lnb and replace with new one
Username: Jballer
i have a seprate dish for 118 and it is 30''
NO Bashing
Post Number: 3139
for lnb freq you need 10750 and for tp freq try 11940
Username: Jballer
Post Number: 7
ok so i m like getting some channels now but not all i am gettin 790, 793, 795, 809 nd 812 but i m missing the others, what do i need to do??
Post Number: 4975
again need more info which dish?
what kind of mesage u are getting?
Username: Jballer
Post Number: 8
i am not getting any message because the channels are not there on 118 but for 61.5 they are there but i get black screen and after a while it says connecting...please wait
NO Bashing
Post Number: 3143
is the light green on the khub???
Username: Jballer
Post Number: 9
the light on the hub is green
Username: Brampton
Post Number: 42
hey gyrad
where did u get the kbox from
and how much
just a question!
Username: Jballer
Post Number: 10
i got it frm a shop near kennedy and steeles for 185
Post Number: 4983
gyrad did u got it working
what dish u have 61..5 or 118.7
gyrad ddoell
Username: Jballer
Post Number: 8
Posted on Monday, May 25, 2009 - 02:15 pm: Edit Post
"i am not getting any message because the channels are not there on 118 but for 61.5"
i am confused with ur statement
Username: Jballer
Post Number: 11
nope its still not working...with that statement i was saying in the guide if i switch to 61.5 the channels are there but are a black screen but if i switch to 118 the channels are not even in the guide
Post Number: 4985
so basically u do have 118.8
go to menu dish setting and tell me what kind of setting u are seeing on ur 118.8 dish
Username: Jballer
Post Number: 12
LNB Power - On
LNB Type - Single
LNB Frequency - 10.750
LNB 22KHz - Off
DiSEqC SW 1.0 - 2
DiSEqC SW 1.1 - Off
Legacy SW - Off
Post Number: 4987
all ur settings are correct. i hope u get both level and quality signal ( both should be green ) and 118.8 dish name right on top..
what kind of message u are getting once u tune in to any channels?
is ur green light on khub on?
do u have latest bin can check it from system information (should be 1.84)
are u in network mode,
go to menu option, change mode to network.
Username: Jballer
Post Number: 13
Both the quality levels are green and on top it syas echo 118 west and light is green on the hub and i have the latest file 1.85 and i am in network mode...the thing is that i cant go to the channels because they are not in the guide for 118 i only get a few channels liek 809 812, 793 and 790
So i think i am doing something wrong and am not scaning properly or something cuz i am unable to pick up the rest of the channels
Username: Jballer
Post Number: 14
the level is 95% and Quality hovers around 82%
Post Number: 4990
oh i got what u mean,
press ok button then with remote move the left button and take it to the top where it says all that will show u all the channels , u can also move it to a-z where it will show u all channels alphabatically
or a,b c i think thats what u have right now which will only show individual channels alphabtically
i
Username: Jballer
Post Number: 15
nope still no luck
Username: Jballer
Post Number: 16
when i scan i am not able to pick up the indian channels...can any1 help please, what am i doing wrong?
Username: Frobi
Post Number: 332
Sure you have the correct LNB for 118 / 119 ? LNB for 61.5 or 110 will not work
Username: Jballer
Post Number: 17
my 110/119 dish is seprate from my 118 dish
Username: Frobi
Post Number: 334
gyrad, I had the same problem and spent over 2 hours. After changing the lnb (118/119), I deleated all channels, checked settings, checked cable ends and scanned. (yours settings are ok as you mentioned above) I was successful. When you scan, say ALL channels, not just FTA
Username: Jballer
Post Number: 18
this is my dish setup
Username: Jballer
Post Number: 19
so do i need to get a new lnb for my 118 dish?
Post Number: 4993
gyradd dodell can u post pic of ur dish setting?
also about channel scan or channels u are not seeing.
Username: Jballer
Post Number: 20
Username: Jballer
Post Number: 21
as stated before i am getting some channels but i am missing many like b4u and sahara sony
Post Number: 4994
so basically u are watching other channels and missing b4u , sahar and sony
so here is to get those channels
go to menu installation, mannual scan
sat name is 118.8
freq for sahara tv 12,033 ,go to freq and find this freq , if this freq is not listed u can do add tp by pressing green button and put freq 12,033 freq 20000 leave polarity and scan the channels from there
for sahara tv/b4u and sony
freq is 12033, horz, 20000
same for b4u and sony ( so just do only once ) and u will get all those channels
Post Number: 4995
https://www.ecoustics.com/electronics/forum/home-video/570254.html
or check this thread i posted my k1plus channels list i am not sure if u can download it
but if u wanna try try to save it on usb and then download it from there, make sure u remember the name ,
before doing that go to utilities data transfer and save current setting from there u won't loose ur current channels list that u already have..
Username: Jballer
Post Number: 22
sada thanks tht worked i got most of them now, i m missing b4u music now can you tell me the freq for that 1 also please and thankz again
Post Number: 4999
12050,ver,20,000
u are welcome and enjoy
Username: Jballer
Post Number: 23
thankz a lot it all works
Username: Jballer
Post Number: 24
juz realized i am missing zee tv can someone please tell me the tp thanks
Post Number: 5001
gyrad for zee tv its 12002 h ,20000
Username: Waqarkhan1971
Post Number: 31
sada you r the best . I
I hope your solution to mine also can work.
If you can reply to my IP address question . I will appreciate
Username: Leo_here
Post Number: 120
All Indian channels on 118 are showing Processing.....Please Wait !
Anyone else having same issue??
Post Number: 5005
leo just reboot ur hub , unplug and plug it back,
