Will this amp handle .66ohms
Username: Armykyle1
Ms Us
Post Number: 571
BXi2608D
what do you think this thing will do if it can? If it could the gain will be set low, all I need is about 1700watts-1900watts. I'll be running 3 D2s subs, what do you guys think the final load will be when its all hooked up. Subs are RL-i 10s
Username: Snowball123
West Allis, WI
Post Number: 2756
why. I wouldnt go with hifonics if it were me. but that's just me.
Username: Armykyle1
Ms Us
Post Number: 572
I can get a good deal on it. And if it works it works, even if it is over rated. I read a few threads about ppl getting rated power out of that amp @ 14.4 less at than rated at 12 of course. If it will go below 1ohm then I'll get it, if not then I wont. I wouldn't be able to get the saz-2000d on the sale price right now.
How much would you be willing to add to the trade with the amp?
West Allis, WI
Post Number: 2757
you name the price. not i.
West Allis, WI
Post Number: 2758
40 bucks on top of shipping?
Username: Deadrabit
Marionville, MO
Post Number: 1802
it will be fine at low ohms. a freind of mine runs his lower ohm daily and has for a year
Username: Armykyle1
Ms Us
Post Number: 573
thats it?
Username: Cozce
St. Louis ILLside, Pronounced: ... U.S.A.
Post Number: 741
.66 before or after imp rise??
Username: Armykyle1
Ms Us
Post Number: 576
before. The ohm load will be .66 on paper
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 3337
good luck, I wouldn't do it.
Username: Armykyle1
Ms Us
Post Number: 589
I wouldn't name my kid mark either but your parents did it lol
Username: B3n07
Louisville, Ky USA
Post Number: 1087
all you can do is try it if it gose to protect shut it off
Username: Armykyle1
Ms Us
Post Number: 591
I lied its .67 so like .80 with imp rise?
Username: Bumpin_buick
Appleton, Wisconsin USA
Post Number: 235
whats the real read on the subs. My guess is the coils will read around 1.4-1.6 as very few companies do exact readings. This way it kinda counters the impedance rise, also are you just guessing on .8 with impedance rise or have you checked it with another amp? Just curious, as that will help me give you a better answer.
Username: Armykyle1
Ms Us
Post Number: 592
it was a guess. I put my dmm on each coil last night, 4.6-4.8 I wired all the subs up, no amp though, and I came up with 1.2. So I'm pretty sure I'll be fine
Username: Hittin1
Post Number: 3343
did you also check to resistance of your DMM to get those readings on the coils? On the same DMM settings touch the red and black probes together and subtract that reading from each coils readings. i'll bet that you get .6 to .8 ohm reading when you do what I'm talking about. If not then those coils may have problems
Username: Allthingzaudio
A - TOWN - WEST-END, GA USA
Post Number: 99
you could but how long to them amps last when pushed hard?
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2624
"all you can do is try it if it gose to protect shut it off"
Unless it blows first, then it will shut itself off haha.
"I read a few threads about ppl getting rated power out of that amp @ 14.4"
Bench results with a scope? or people using a clamp and dmm?
Username: Armykyle1
Ms Us
Post Number: 593
yeah, I got .7-.8. so do I need to subtract that from each coil or the over all ohm load?
On the testing, I read one bench test I believe 2701 @ 14.4v 2621 @ 13.8v or something and 2450 @ 12.2v
another one was 2589 @ 14.4v 2501 @ 13.8
But if its over 2k I really dont care. I don't need that much.
West Allis, WI
Post Number: 2766
Sundown SAZ-2000D ftw.
Username: Armykyle1
Ms Us
Post Number: 594
if I had the 485 to get the pre order price I would lol.
I found another test and it did 2589 @14.4v
Username: Hittin1
Post Number: 3348
why worry about such a low ohm load. Wire them in series, parallel for a 1.34 ohm lload. should still be close to your 2000 wrms. plus amp will be better off. That seems to make the most sense to me.
Username: Hittin1
Post Number: 3349
ohhhhhh snap.. Are those Yanks old subs?... He really likes SS subs.. I mean REALLY likes SS subs... be sure to check for stains on the cones.. If he didn't clean em up, you could probably just scrape the j!zz off if you are carefull..
lmao j/p
West Allis, WI
Post Number: 2769
Yanks never owned Rl-i's.
Username: Hittin1
Post Number: 3351
lol well fack.... I know someone on here was selling them, my memory is slippin' in my old age, i guess.
West Allis, WI
Post Number: 2771
was the M dude. He's mostly over at j-designs. member?
Username: Armykyle1
Ms Us
Post Number: 595
show me how the wiring setup looks that ur talking about?
Username: Armykyle1
Ms Us
Post Number: 596
Heck I might just wire it to 2.67, and listen to it like that for a while so how I like it.
Username: Hittin1
Post Number: 3356
where are you getting 2.67 as a possible impendance? the next option would be 3 ohm then 12 ohm
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=3&I=22
Username: Armykyle1
Ms Us
Post Number: 597
lol sorry, I put D2s..... They're D4s
Username: Armykyle1
Ms Us
Post Number: 598
do I subtract the .7-.8 from the over all ohm load?
Username: Hittin1
Post Number: 3357
you are in the same boat i am in, if you run them paralleled all the way, you are looking at ~.34 ohm before imp rise, which I will be doing for burps and 1.34 for daily. The .34 or so load is absolutely out of the question for the hifonics amp.
Username: Hittin1
Post Number: 3358
d4's changes everything. sonofa...lol
nvm go with what you know.
Username: Hittin1
Post Number: 3359
As for the .7 DMM reading. If you have all subs wired together then you are looking at the ohm load, then you would subtract .7 from that. But if you are reading each coil individually then you would subtract it from each reading.
Username: Armykyle1
Ms Us
Post Number: 599
so it'll be like .95 I don't think that should be a problem. Thanks guys
