Silver Member Username: Imars99Post Number: 215 Registered: Aug-06 | Which Lnb and dish i suppose to use for 118.8 ? |
Silver Member Username: Imars99Post Number: 217 Registered: Aug-06 | Sada if you are online pl answer my question. |
Silver Member Username: Imars99Post Number: 218 Registered: Aug-06 | Can i use Circular Lnb with 18 inch dish. |
Gold Member Username: Saqeeb9000Post Number: 4942 Registered: Oct-07 | https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1612835#POST1612835 here u go rocky the picture of lnb |
Gold Member Username: Saqeeb9000Post Number: 4943 Registered: Oct-07 | King Tapeman Gold Member Username: Tapeman New York City in-HD, NY Post Number: 3427 Registered: Oct-06 Posted on Thursday, September 11, 2008 - 12:03 am: Edit Post - Single Circular LNB like 118 don't require LNB tilt - 2 Satellites for circular require skew entire dish but no LNB tilt That's because of position of satellites on King's belt i forgot b.w circular and linear lnb i am quite sure it was circular lnb, u need atleast 36 inch dish, |
Silver Member Username: Imars99Post Number: 219 Registered: Aug-06 | Thanks Sada. |
Silver Member Username: JoeturnPost Number: 571 Registered: Apr-06 | Pay close attention to this excert from that thread: Gold Member Username: Tapeman New York City in-HD, NY Post Number: 3427 Registered: Oct-06 Posted on Thursday, September 11, 2008 - 12:03 am: -------------------------------------------------------------------------------- - Single Circular LNB like 118 don't require LNB tilt - 2 Satellites for circular require skew entire dish but no LNB tilt That's because of position of satellites on King's belt - Any Linear LNB for Linear polarity must be tilted or it won't work - Providers use circular polarity for easier installation with multiple satellites $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ Clarks Belt The reason a vertical only lnb wont work on a H-H motor is because it changes from total vertical to partial v/h to total H during the swing of the offset motors arm. When this occurs due to the swing of the motors arm the DB will be too low! So it is best to get the(spit..)circular LNB and a larger dish! Circular Lnb was the tecnical word for combing the old V/H lnb ports internaly. The new sats transmit both vertical and horrizontal simultaniously on their new helical transponders to overcome probagation!! The helical designed transponders are easily ressesed a bit for shielding,to keep them from interfering with each other as the old aray tranponders could not be shielded TVI |
Bronze Member Username: PeggPost Number: 78 Registered: Aug-06 | Is it must to get at least 30 inch dish in Canada (montreal) to catch 118.7 and 119? Is appropriate LNB on 18 inch dish not enough? |
Silver Member Username: JoeturnPost Number: 573 Registered: Apr-06 | Go load echo 9/13 @10750 and see for your self! A larger dish will overcome rainfade!! |
Gold Member Username: PlymouthCanada Post Number: 9349 Registered: Jan-08 | Pegg Yes a 30" and bigger and a CB2008A |
Gold Member Username: RiconissanPost Number: 1014 Registered: Feb-09 | joeturn has BRAINFADE |
