i just replaced my lnb's with a dish plus lnb and am trying to figure out the best setting ......but the thing is when i change the tp frez.. and exit and save it wont save it goes right back to 12224. thanks for any help also when i do a scan of my channels i get a butt load of doubles and when i delete one of the doubles it deletes both of them thanks again for any help
Plymouth, I have luck with standard LNb setting and legacy switch setting to match the signal and quality 119 12239 and 110 12224. I do not try for 118.8 with the DP LNb and Viewsat. Of course Diseq None.
Rico If you use a Dp LNB the 22 Khz can be used but I don't recommend the Dp dish for some reason, but I use a Bev dish on Spare for my bedroom because I had one, It's not my best one but a Fortec 33" which I can get many satellites and never lose signal on Dn.
I have a Vs Ultra(not Lite) and I 'm able to deleted only one of both channels.
In Edit Channels select the channel to deleted with arrow up and down then press one time on right arrow for select the garbage can the press "OK" and the channel is gone, you use again arrow up or down and select another channel to deleted then press "OK" again.
