Radio Code
Username: Jet1963
Can anyone help me i have a 2001 peugeot 206 ive had it for past 7 years and never needed radio code, now i do as i have had to change battery and the radio is asking for code!!!!!!! i cant find it on any of my paperwork peugeot reckon i will have got a card with it on but cant find it !! Please can anyone help?????????
Username: Hay88
Post Number: 560
Jet1963 you need to remove the radio then post the model/letters/numbers off of the radio for help.
Username: Jet1963
Thank you
i have these nos is this right
Model no PU-2325A (B)
CL0410Y0092999
Username: Hay88
Post Number: 561
Jet1963 have you got another barcode like C7000000XXXX Cause only ones with that type can be done from serial.
Username: Jet1963
just the serial No. above the bar code which is CL0410Y0092999
Username: Regrooster
Post Number: 3666
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Username: Eliem
Hi, can someone please help me with a code for renault senic 2004
serial number: RNRD0340119192
security code: H327
Thanks
Username: Hay88
Post Number: 566
Eliem
your code is 4000
Username: Eliem
thanks it works!! your a star!
Username: Khazaddum12
Hi can any one help me with a renault scenic code?
Got all these numbers off the side of it, so i hope one of them is right.
RNRD8460044568
FD0206100044568
R810 Security
8200 550 822
RENRDW 232-70
Thanks
Username: Hay88
Post Number: 577
Khazaddum12
your code is 8161
Thank you very much
You are a very wonderful person.
I am Driving for 5 hours tomorow and would have gone round the twist with out the radio.
Username: Badboyfsd
hi everyone i have mercedz model E420 i have lost my radio code how can i get it plz help me anyone i will very thankful to you plz...........
Post Number: 3681
hassan
Username: Badboyfsd
Posted on Sunday, April 25, 2010 - 03:44 pm:
Post the radio MAKE + MODEL plus all the letters+numbers on any labels , barcodes or stamped in the metal casing
Username: Mickey_dino
London
My dad has a Renault Scenic and his mechanic took the battery off for some reason and now his radio won't work. I have managed to pull the radio out and taken the following numbers off the side.
Can anyone help with the code I need to enter as I can't find anything on his paperwork.
Model No 22DC259/62P
PROD NO FD0501 4203 16771
TOU372
RN259 F1031 6771
7700434424 TU372
This is all the numbers I could find.
Many thanks.
Mickey D
London
TOU372
RN259 F1031 6771
7700434424 TU372
Many thanks.
Mickey D
London
TOU372
RN259 F1031 6771
7700434424 TU372
Many thanks.
Mickey D
London
TOU372
RN259 F1031 6771
7700434424 TU372
Many thanks.
Mickey D
Username: Hay88
Post Number: 669
Mickey_dino
your code 5652 i have sent email how to enter
London
Many Thanks Hay 88. I will pop round to see him tomorrow and try it. He will be over the moon. Thanks again.
Mickey D
Username: Smbrst
Need help!! Just bought a 1989 bmw 735i with a radio asking for a code. I pulled out the radio but there are no bmw dealerships in my area. Please help! serial no. says FCC ID: AJD4DIKE-83ZBM
Thanks.
Username: Hay88
Post Number: 673
smbrst that a pioneer i think your find its a five digit.
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Username: Smbrst
Thanks
