Username: Plymouth Canada
Post Number: 9199 Registered: Jan-08
Friday, May 15, 2009 - 13:31 GMT Now we can save our channels and satellites on USB keys. We can also transfered the channels list to another users.
Username: Bernardmi Post Number: 441 Registered: Dec-07
Friday, May 15, 2009 - 15:36 GMT What is it ? You just discovered Channel Master exists ?
Username: Waqarkhan1971 Post Number: 5 Registered: Mar-09
Friday, May 15, 2009 - 15:53 GMT how do you do that
Username: Waqarkhan1971 Post Number: 6 Registered: Mar-09
Friday, May 15, 2009 - 16:06 GMT Plymouth Could you please tell me the procedure for it
Username: Bernardmi Post Number: 443 Registered: Dec-07
Friday, May 15, 2009 - 16:07 GMT Probably out for lunch !
Username: Chumley Post Number: 186 Registered: Dec-08
Friday, May 15, 2009 - 16:27 GMT How To: Insert USB in receiver for saving channel list: press MENU > SYSTEM INFORMATION > RECEIVER UPGRADE > Channel > Select device > USB > Start Transfer for saving Satellite list: press MENU > SYSTEM INFORMATION > RECEIVER UPGRADE > Satellite > Select device > USB > Start Transfer same procedure for Key Data this process is meant to keep a copy of your Chaninfo & Satinfo as a backup... and now u can import those files to Channel Master for editing Chan info file can be loaded back to receiver if u did a factory default... it restores your channel lineup and Favorites that u have programmed.
Username: Waqarkhan1971 Post Number: 7 Registered: Mar-09
Friday, May 15, 2009 - 16:30 GMT wonderful. Thanks Chumley
Post Number: 9200 Registered: Jan-08
Friday, May 15, 2009 - 17:32 GMT Good post Chumley But you don't need Channel Master but new Ultra loader with channel Editor avilable at viewsatusa.com The thing is: I can send you my file if you are not able to get a channel or this channel is hidden.
Username: Riconissan Post Number: 879 Registered: Feb-09
Friday, May 15, 2009 - 18:45 GMT Viewsats does it again. Great support for their product.
Username: Bernardmi Post Number: 449 Registered: Dec-07
Saturday, May 16, 2009 - 13:14 GMT But could you not do that before using Channel Master ?
Post Number: 9217 Registered: Jan-08
Saturday, May 16, 2009 - 14:48 GMT Yes Bernard, but Channels Master doesn't work very good with Viewsat and the only way for saving the channels was with RS-232, now it work on USB port.
