New member Username: Gwm5225Post Number: 4 Registered: May-09 | Anyone heard of Bassforms out of Newport Beach Ca., i am searching for a good sealed box for my truck and this company is claiming to have the best sealed box with its tech and air space...? anyone have one? www.bassforms.com |
Silver Member Username: DuckaHoughton and/or Macomb, MI United States Post Number: 988 Registered: Jan-08 | Are you capable of building one yourself? Cheaper and you know it will be made just for your subs. |
New member Username: Gwm5225Post Number: 6 Registered: May-09 | Yeah want to but dont have the tools. ![]() |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 281 Registered: Dec-08 | ok look. if you know any friends that have a saw, you can build a sealed box. its the easiest box to make of all. just make sure the airspace is right on the inside ( minus all sub displacement and bracing) and screw the sides together. good to go. |
New member Username: Gwm5225Post Number: 7 Registered: May-09 | Cool...Thanx for the info! |
New member Username: Roman_noodlesBalling, Usa Usa Post Number: 8 Registered: May-09 | A sealed box is a sealed box. Just makes sure not 1/2 or 5/8. |
