Silver Member Username: JoeturnPost Number: 378 Registered: Apr-06 | I have found out that this one is suitable for all DBS sats, you only use one port! If you have multiple recievers you only need an inside DIP switch ! No more hassle of dip switch setting just select none an go! http://www.tvtoyz.com/lnbs/directv_dual_lnb.htm |
