Issue with the new Pansat bin file.
Username: Arcvile
I am getting the "scrambled or bad channel" message after I loaded the newest bin for my Pansat 2700A, and all I have done was go to channel 8282 and set the keys to default is there anything that I am missing/should do?
Username: Fatback
Post Number: 81
put the keys in manually
Username: Joeturn
Post Number: 268
takes 30 minutes
Username: Crazycool
Post Number: 61
And also go to autoroll options and make sure that autorol is off on whatever provider you are using, dn,gc,bev.and set defolt keys.then put in the new keys
key1: 42 61 31 A5 B6 7F 4C A8 32 74 4C 24 8C 94 56 AB New
Username: Legend_killer
Post Number: 178
I tried that but theres still alo of freezing.
Username: Mkvl1490
Post Number: 178
Yea it still is
Username: Plymouth
Post Number: 9015
Guys
The keys doesn't work, wait for new bin.
