Nalin/Plymoth IS VIEWSAT ULTRA UP? FOR NDTV and PPV
Username: Kashif
Post Number: 30
I lost my NDTV and PPV yesterday, and my viewsat ultra showing no quality and less weak signaL, my question is is that me only? and if yes hoe can i get my channels back.
Thanks in Advance
Username: Riconissan
Post Number: 716
DAVID KAISER,
I may be able to help you. If you are not getting signal it may be corrosion in one of your cable connections. Or something has changed in your dish alignment. If you do not think your dish has moved. Is it possible that a tree or bush in your line of sight has bloomed?
A software problem (bin) will not cause you to lose signal.
J
Username: Plymouth
Post Number: 8982
David reload the latest bin and check your satellite setup, sometimes with a new bin you lost the setting in satellite setup.
Username: Picanha
East LA
Post Number: 407
Corrosion!!!! The tree or bush is up your azz you DumbFukUpload
Post Number: 717
Schools out. Esvaldo will be here until his mom gets off the pole and makes him go to bed.
Username: Kashif
Post Number: 31
No body answer my question, is that me only? not getting NDTV and PPV
Post Number: 719
PPV are up.
Username: Plymouth
Post Number: 8987
David
PPV still up But P0rn down, NDTV was up yesturday.
List your receiver?
