Viwssat ultra lite
Username: Drgnhilord
hello people,i am new to all this but i bought a viewsat ultra lite a week ago. and installed it, had it up and running but when the file went down . i downloaded the new file today and i updated my box. well now i cant get any channels at all. can some one pleas point me in the right direction.. thanks
Username: Plymouth
Post Number: 8932
charles tyler
Be sure that you have loaded the good file, "U" is for Ultra and "UL" is for Ultra Light.
Here is the good files:
[link removed]
yeah thats the file i had. the one with the ul at the end.should i be doing any thing before i load a new file or just update the box..i put the file on that u gave me the link to but still no luck. is it possable that my dish needs to be reaimed thanks
Username: Plymouth
Post Number: 8934
Charles
List the satellites you get.
How is the signal and quality?
Be sure the LNB Type is right.
the sat i got is a disnet 500
my sinal on S 80 Q 86 to 90
how can i tell what lnb i have thanks
Username: Plymouth
Post Number: 8935
Check in Menu, Installation then Antenna Setup and list what you see.
Echostar 7 119.0w
lnb power on
lnb type universal
lnb high 10600
lnb low 9750
tp freq 12224
DiSEqC 1.0 none
motor off
legacy SW none
also i dont know if it matters but i have a direct connect from sat to box no switch thanks
UPDATE
i got some channels back, but i dont have PPV and probably alot more. not sure how many channels i should have, also i am trying to point at ecostar 119 w
but my box keeps telling me im looking at ecostar 10,11, 110w how do i fix this thanks
Username: Chumley
Post Number: 116
try lnb type: OSC-DP
assign diseqc port 1 for 119 and port 2 for 110, your lnb has an internal disecq switch
Post Number: 7
no luck! i changed the lnb type and the port. is it my lnb is wrong maybe i need to buy a new one. my buddy told me that not all dishes can get ppv and other channels is this true thanks
Username: Plymouth
Post Number: 8941
Charles
Try it:
Echostar 7 119.0w
lnb power on
lnb type: OCS-DP or Standard
lnb Freq: 11250
tp freq 12224
DiSEqC 1.0 none
motor off
legacy SW none
Post Number: 8
ok will try thanks
Post Number: 9
ok thanks for the help plymouth i got the ppv channels now. like i said i am new to this. about how many channels should i be getting. as of right now im getting like 316 plus 2 music again thinks for all the help from every one great site
Username: Plymouth
Post Number: 8956
Charles
You are Welcome!
You can do a Blind scan then a auto scan for get maximum channels.
If you have duplicated channels you can deleted it in channels organization.
Post Number: 10
ok thanks
how do i do a blind scan i dont see it any where in the menu i have a viewsat ultra lite also i have lnb's on my dish do i need both of them hooked up
Username: Plymouth
Post Number: 8958
Charles
Sorry you are right, Ultra Lite doesnt have blindscan.
Usualy the second LNB is for 110W which you can get over 500 channels.
You must have a Diseq switch and put the 119 LNB on port 1 and 110W on port 2
I get 298 channels on 119W
Post Number: 11
so i can use 1 dish for both 119 and 110 do i have to redo the position of my dish to do that
Username: Plymouth
Post Number: 8961
Charles
Yes, you can get both, you will need to reaimed your dish.
Use this utility for aimed your dish:
http://satcalculator.freehostia.com/
Username: Chumley
Post Number: 117
Charles claims to have "the sat i got is a disnet 500" and this "also i am trying to point at ecostar 119 w
but my box keeps telling me im looking at ecostar 10,11, 110w"
Plymouth what is dish 500
You are welcome!!!
Username: Riconissan
Post Number: 713
Charles
If you have a DP Lnb
Try putting Diseq to "none" and change Legacy switch setting leave it for a few seconds and note which setting gives you 110 first and then 119. These are the settings you will need to receive these birds.
This is the point Chumley was trying to make. It would be too hard for her to explain herself because she is a little bit shy.
Username: Nydas
Post Number: 14969
Charles:
Do you have Dish 500 or Dish 500+? These are two different dishes.
The Dish 500+ setup usually has separate LNB next to the main LNB for 118 and 119
The original settings you described are those for getting ANIK F3 (as well as ECHO 7) on a Dish 500+. The Plus Dish is about 30" wide.
You might want to look for a separate LNB next to it which is meant for picking up 110W
Post Number: 12
thanks for all the help every one. i have a dish network 500 dish 2 separate lnb's. am gonna try and hook them both up this weekend .thanks again for all the help every one
