Epg in pantec...
Username: Legend_killer
Post Number: 165
i have a sonicsat pantec 2500 and the epg is riducolous, it only shows an hour worth of epg while my viewsat lite before showed a 24 hour one.
any way to get the epg for at least 12 hours or so in pantec 2500?
Username: Mzakcat
Post Number: 130
no 8 hour max, and rarely if ever, turn it off and on and get 2+ ?, as long as time and date are set correctly
Post Number: 167
time and date are set correctly i believe (it shows the right time, the time zone is right as well), so why i only get an hour?
Username: Mzakcat
Post Number: 131
what sat are you hitting, i believe 119 carries more epg info? I can't remember the post but someone once said to tune to a certain channel for guide load, but i do remember that channel was an echo7
Post Number: 168
ya that was channel 200, but that worked only on ma viewsat.
Username: Nydas
Post Number: 14958
For converted receivers, there is a big problem with memory. Hence you won't get more than 2 hour EPG.
