Arizona's Satellite Caribbean
Username: Nightnurse
Post Number: 19
Hello I am from the caribbean and was recently told to pick up that satellite I will have to change the lnb and then re-program the box,I have a viewsat extreme,is there anyone in the caribbean,st,lucia,barbados,trinidad etc that is picking up the signal and will be to give me steps on how to reprogram the box or find new files?
Username: Gastrognome
Post Number: 105
Amazonas 61w
load file like you normally would- files can be found where you usually get them from -also the latest bin may contain the telefonica fix - i don't know
DBPSW-090417X Telefonica AR Fix
https://www.ecoustics.com/electronics/forum/home-video/559455.html
btw , i don't get that sat and am no where near the caribbean
good luck
Username: Laxey34
Miami, FL United States
Post Number: 78
I am in St. Vincent and I can view this satellitew on a 120cm antenna with 70% quality signal on most transponders. I believe the programs is in spanish.
Post Number: 20
Anyone else???
