New member Username: Norske_kronerSanfrancisco, Cal U.s.a Post Number: 3 Registered: Nov-08 | where can I find LNB for dn's 129. If any one knows price and place. Will STARCHOICE's lnb work with dn 's 129. |
Gold Member Username: PlymouthCanada Post Number: 8972 Registered: Jan-08 | norsk I get 129(Echostar) with same LNB as for 110-119-61.5 |
Gold Member Username: GregrafPost Number: 2775 Registered: Dec-07 | norsk starchoice lnb wont work. |
New member Username: Norske_kronerSanfrancisco, Cal U.s.a Post Number: 4 Registered: Nov-08 | So you guys telling me that the one We use to get 148 will work to get 129.Is that right. For me what size dish I must have ? Same as I used to get 148 will work. I appriciate your help. |
Gold Member Username: PlymouthCanada Post Number: 8973 Registered: Jan-08 | norsk You can get 129 with a 18" dish but most of channels are HD |
New member Username: Norske_kronerSanfrancisco, Cal U.s.a Post Number: 5 Registered: Nov-08 | Thank you sir. |
Silver Member Username: JoeturnPost Number: 271 Registered: Apr-06 | All dbs LNBs are compatible you only need to go into antenna setup and change the LNB type for the greatest quality.Then back out till you get to blind scan and select scan all!! |
New member Username: Norske_kronerSanfrancisco, Cal U.s.a Post Number: 6 Registered: Nov-08 | appriciate Joeturn |
New member Username: Norske_kronerSanfrancisco, Cal U.s.a Post Number: 7 Registered: Nov-08 | I have never hit dn 129 while trying to point at other sats. Is this recently launched. How long ago. |
Silver Member Username: JoeturnPost Number: 277 Registered: Apr-06 | This is normal you have to have your LNB trained at Ciel 2s focal point!! http://www.fourmilab.ch/earthview/satellite.html http://en.wikipedia.org/wiki/Ciel-2 |
New member Username: Norske_kronerSanfrancisco, Cal U.s.a Post Number: 8 Registered: Nov-08 | joeturn, I didn't get that. What you mean by "have your LNB trained at ceil2s focal point" Thanks. |
Platinum Member Username: NydasPost Number: 14998 Registered: Jun-06 | Ceil 2 is a Sat at 129W http://www.lyngsat*com/packages/dish129.html |
New member Username: Norske_kronerSanfrancisco, Cal U.s.a Post Number: 9 Registered: Nov-08 | I appriciate your help. |
