Thanks for the help guys but i need one more thing
Username: Wfbass
Stephenville, NL Canada
Post Number: 78
what size box should i biuld for the 12" audiopulse axis? also what port area and what should i tune the port to?
Username: Rovin
1 15 = 149.5 DBs ...Trinidad & T...
Post Number: 14913
im sure if u email the company they will help u ...
Username: Drant19
DUB-C, TX
Post Number: 1564
^x2
that would be your best bet. maybe they have a forum?? im not sure but it would be worth checkin into. also the manual should have some specs that would give you "optimal" enclosure specs.
Username: Wfbass
Post Number: 79
yeah most likly, i should have asked if anyone had any exp with the sub and enclosures for it maybe...
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 3110
One of the best features of the Axis is that it needs very little box volume to thrive. it needs no more than 1.5 to 2^3 ft. after displacement.
When I was looking at running two of em(15's), I was looking at 4 ^3 ft. 80^2 of port. tuned to 32-33 hz for daily.
Username: Prozack52
Cincinnati, 2-audio puls...
Post Number: 529
mike from exige audio may be some help to u too he sells audio pulse
