119 Great. 118.7 have channles but no A/V. Help!
Username: Waid
Indiana USA
I just installed a new big DISH 1000+ with FSS/DBS Dual Band LNBF so I can receive 119 and 118.7. I am so using DP34. Eveything works perfect with 119. With 118.7, I receive all channles but it says there no audio or no video. I tried resetting, reloading files, rescanning, blind scanning. Nothing seems to work. The signal is 85% with quality of 75%. I know its not the switch because I tried hooking the LNBF directly bypassing the switch.
Any suggestions ?
LNB Power On
LNB Type OCS-DP
LNB Freq. 10750
22KHz Off
TP Freq. 11715
DiSEqC Port 3
Motor OffUpload
Username: Nydas
Post Number: 14883
You have tried everything you should.
Try LNB type Standard and Universal and see if you get anything.
Username: Perycles2005
Post Number: 90
I suggest to check again your dish position...seems your signal is low...or you can use a regular amplifier...I've used an amplifier before on a situation like that and it worked...good luck
Username: Joeturn
Post Number: 233
Sounds more like a mistake in keys but it should say SCB!
I scanned 101 once and got DTV but the audio and video were on two different transponders&%^$%
Try to borrow a friends working STB for a comparison!
Username: Jet9508
Post Number: 52
is the international channel in 118.7 still working? I just came back from vacation and all the internation channels from 118 said no audio and video.
