My mind is all over for subs
Username: Tylersliva
St.Ignace, Mi U.S.
Post Number: 248
ok guys ive been learning alot latly and i just found out that 2 12s would be louder than 1 12 cuz of cone area... i was planning on gettin a single AQ HDC3 but ive been thinking what about 2 12" alpine type R??? would this be a nicer setup than the audioque?
Username: Poprocks
Post Number: 144
Forget everything you have posted.
Build a custom box for your 2 Kicker CVR 12" and go from there.
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 3202
2-12's are NOT always louder than a single sub setup...
Your first mistake was listening to dBLK in the other thread. Take anything he says with a grain of salt.
Username: Prozack52
Cincinnati, 2-audio puls...
Post Number: 536
a lot of how loud a system get depends on the install man
Username: Insearchofbass
Post Number: 11413
We have made a single 12 setup almost as loud as 4 12's in a guys vehicle. It was one of the four 12's he had too. No brand change.
Post Number: 11414
I do think two alpine 12's would be as loud as the hdc and they will have better lows and sound quality. Just make sure you have 4 cubic feet net to give the pair.
Username: Drant19
DUB-C, TX
Post Number: 1571
2 12' type-rs
4.5 cubes tuned to 32-35Hz (w/out driver displacement)
a good 1200rms would do them nice.
i would go with the type-rs over the single HDC, because of the same reasons sean said: better lows and SQ, and could be louder than the HDC if done properly
