Over the weekend my bud tired to do something to his box, i guess put in a different file or something. but whatever he did, his box wouldnt work.
So today he gave it to me, to try and fix. Now on my box, i get s80 and q80, or so. But when i connect his box, i get a s80, and q0. Now i tried a factory rebot, and installed the last available file, and got nothing. i also noticed the date is set to jan 01, 1900.
tried everything i could think of. Is his box done??
Try changing the LNB Type. If you are pointing at a bird and your settings are correct you should have signal and quality no mater what bin you are using. List your equipment and your settings.
got it to kinda work now. started playing arounnd with the LNB FREQ. and was able to get a signal and quality, But now with the file 4/17/09(viewsat utra) got no picture.
