Amp clips low power
Username: Luises14
Midlothian, IL
Sorry this is probably obvious but I havent had this happen before. I have a hifonics sampson that has a little clipping indicator light, and it says its clipping at which I know is nowhere full power, what I figured is that im not powering suffiently, it doesnt distort or get warm, nothing its a good amp. what do you think?
btw I have have 8 optimas but still have the stock alt , waiting for my new irraggi
Username: Basebalz13
Moneta, Va Usa
Post Number: 1514
eh if you can, get your money back from iraggi
and what kind of wiring do you have going from the front to back, and into the amp?
Username: Luises14
Midlothian, IL
its all zero gauge the batterys up front are doubled ground to the car with zero gauge,
Not a fan of iraggi?
