Shallow Mount Sub??
Username: 09f150screw
Oklahoma City, OK
Just got a new truck and I need some suggestions on a new sub. I'm looking for 2 12's but the problem is they have to be 5" deep or less and need .75 cu ft sealed. I have 2 old Ascendant Audio Arsenal 12's but they're way too deep for me to use. Power requirements aren't that big of a deal as I will be buying new amps for this install. I'm hoping to keep under $200 a piece.
Thanks for the help.
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6367
Just use the arsenals and build a console.
Username: Frkkevin
Post Number: 6368
... or learn how to fiberglass and use all the room :-)
Oklahoma City, OK
thought about glassing it but that will buy me less than 3/4".
anyway, I've been looking at Infinity Kappa's, CDT EF-120's, and Diamond DS12's. Any input on these?
Oklahoma City, OK
okay, modify on the size requirements. I spoke with the manufacturer of the box and the mounting depth posted on their site is wrong, it's actually 6". So with the in mind can anyone give me some input on the best SQ woofer would be out of these or if there is a better one I'm missing, thanks.
Ascendant Audio Assassin 12
RE Audio SR12
Diamond Audio D112
Infinity Kappa 12
CDT EF-120
JL 12w1v2
Focal 30A1
IDQ12v3
I'll be using 2 12's in small sealed boxes (.75 cuft) under the backseat of a crewcab truck. Thanks.
Username: Drant19
DUB-C, TX
Post Number: 1535
if your talkin about the kappa perfect 12.1 then my vote is for that sub!
Username: Armykyle1
Ms Us
Post Number: 541
Diamond!!
Username: Kickittothacurb
Post Number: 66
RE
