CNN autorolling
Username: Joed
PLATINUM VIP MEMBER
Post Number: 94
Did CNN switch to N3? What other channels switched?
Username: Plymouth
Post Number: 8784
Joe Devlin
CNN on Echo 7 still UP!
List your receiver.
Username: Nydas
Post Number: 14870
CNN is coming through fine on Echo 7
Username: Joed
PLATINUM VIP MEMBER
Post Number: 95
Problem resolved with power off/on. Didn't think of that right away since only about 5 stations were not working.
Username: Tigger_woods
KICKIN AZZ, TAKING NAMES
Post Number: 1108
As I was saying Joe, CNN is no good anyway!They are also in the tank for Obama. Try Fox on 205 for fair and balanced reporting
Username: Riconissan
Post Number: 651
Good post TW.
Also Perez Hilton needs a good As*s Kicking!
Username: Joeturn
Post Number: 228
Auto rolling!! They are sending false keys changes that cause the unregistered stbs to search for new keys! If you have your autroll cut off you cant get the update without a manual load!
Just watch for the scrambled bad channel.If your autoroll is off cut it back on till the keys get reentered then quickly disable the autoroll so it wont accept bad keys and do a phony search!!
Username: Plymouth
Post Number: 8824
joeturn
It seems that Pansat autoroll not work well
and they need to put the keys manualy.
Username: Shadow45
Mty, Nuevo Leon Mexico
Post Number: 306
my lavasat with the last lzma bin is rolling, it takes it like 5-6 min, but it comes through and i have the auto roll off
