| Tell me a good web site that sells dash kits. |
john robinson | Yes of course dash kits are available online by the dozens! Check out www.veneerz.com. They have some of the most reasonable and stylish dash kits. |
Bronze Member Username: Dread07Oshkosh, Wisconsin USA Post Number: 20 Registered: May-04 | If your looking for wood dash kits go here: http://www.exoticwooddash.com/ For Chrome, Alumnium, carbon fiber go here: www.veneerz.com this site has a large inventory of dash kits that you should find useful: http://incolor.inebraska.com/weisinator/install-kits/metra/dash-kit/ |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 3102 Registered: Dec-03 | www.metra-online.com |
Bronze Member Username: Dread07Oshkosh, Wisconsin USA Post Number: 30 Registered: May-04 | hmm link doesn't work for me |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 3150 Registered: Dec-03 | oops sorry, no hyphen that was from my bad emmory http://www.metraonline.com/ there |
jimmyz Unregistered guest | edashkit.com |
