Beginer question
Username: Madmax444
i dont really know anything about systems or car audio, but im looking into some subs. i dont want just pure noise and loudness, id like some sound quality aswell. i have a buick regal if it matters and it came with a 180watt JVC deck. Im looking to spend under $400 total(subs,box,amp,etc./ i dont even really know what all i need), if thats even possible. im interested on any feedback, recomendations, or anything of that matter. Thanks a lot.
Username: Its_bacon12
Post Number: 655
ok for starters....a great head unit will cost $400 alone so maybe could you up your budget to say $600 and we can work with that easier
ok for head unit, i'd go with a lower end/mid lvl clarion - http://www.cardomain.com/shoplist~b~Clarion~t~CD+Players both are decent head units but i'd reccomend the DXZ445 if u wanna spend the extra $40
sub(s) - a 15 inch elemental designs K.v2 would be awesome, put it in a large sealed box with a BP600.1 powering it and you would be good to go
-$170 head unit
-$100+shipping sub http://www.edesignaudio.com/kv2.htm
-$200 amp http://www.cardomain.com/item/JBLBP6001
gives us about $100 for speakers, so lets get some good ones in the front - try some infinity reference speakers http://www.cardomain.com/shoplist~b~Infinity~t~2-Way+Speakers - about $100 for a pair at circuit city
the elemental designs sub you can purchase only online at www.edesignaudio.com and it's a pre-production sale so they wont be shipped til july 1 but hell i'd wait for it...amp at www.sounddomain.com and head unit at www.sounddomain.com
Username: Madmax444
thanks a lot, i just have a couple of questions, first, do i need to get a new head unit? The one i have is already an after market deck, what would the advantages to getting the clarion be. also can i just get an amp and the sub, then wait till i have more money to get the speakers. Thanks again
Username: Madmax444
also, what is the difference between dual 4 ohm and dual 2 ohm
Username: Pat_l
Tucson, AZ USA
Post Number: 245
I wouldnt bother with a Head Unit, i think its not nessasary for somebody on a strict budget. Get your self some good quality subs and a good AMP. I would look into some Rockford's or Kickers. And a good RF AMP. I found some things on Ebay now the AMP is a Refurb but there just as good and the sub is just one but its 400W RMS, dont worry that sh*t will pound hard (i have one) plus it has a box. Then all you need is wires.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39737&item=5704016207&rd= 1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=32823&item=5704927703&rd= 1
Username: Pat_l
Tucson, AZ USA
Post Number: 246
Oh yeah, Speakers are not nessasary yet! Once you got the sub in than just turn the dial on the deck for treble all the way up. So now you sub is playing bass and the stock speakers are just used for treble. Works well.
Post Number: 666
dont listen to this crack pot...
stock speakers will die within 5 seconds of handling an aftermarket HU
and RF subs are fair to say the most, and RF amps are too expensive to be considered budget
just go with my suggestion, you seriously CANNOT go wrong there
btw, get the dual 4 ohm 15 kv.2 it'll be easier on the amp although it puts out 600w rms at 2 or 1 ohm
seriously though, i cannot name off a better setup for less than that
Username: Godemiche
Post Number: 36
RF are crap.... well the new ones....
Username: Davids2004
Houston, TX USA
Post Number: 135
Ill help ya out here.
Xtant A3001T-125.00
1 Kicker Comp cvr10-50.00
4gauge wiring kit from www.knukonceptz.com -35.00
http://proboxrocks.com/superbass/1-10-SPB.shtml -150-175.00
Post Number: 668
that box is crap
like i said before in another thread u crapped in...BUILD yer own box, save $150
and that comp VR cannot come close to competing with a 15" kv.2
Username: Alpinepower
Post Number: 59
dont go with a 15 inch sub for sound quality, the larger the sub, the less responsive the bass, (but you do get a deeper sound and more feel in the chest). Rapid bass notes can become muddled on a 15 inch sub, tens are tight and cleaner, but the sound is higher pitched, I would suggest a 12
You dont need a new headunit if you go off the back speakers directly into an amp via a line converter, so for $400, suggest build own box (SEALED IF YOU DONT KNOW WHAT YOUR DOING),
Then you need maybe an 12" HE (fosgate) off of a small alpine monoblock, suggest the 700D
Username: Jonathan_f
GA USA
Post Number: 466
Yeah, that box is pretty bad. I'd take a Q-logic box before that one. Building your own is MUCH cheaper, shouldn't be more than 30 bucks, more if you don't have screws, glue, caulk, etc. sitting in your shop (if you have one) Then of course you may want to spend a couple bucks to carpet it. The quality of Rockford really has dropped a LOT since they went retail at Best Buy, their early 90's stuff was MUCH better. Go with Bacons setup, he knows what he's talking about. Kv.2's are awesome. Always put a good set of components in your future plans if you're doing upgrades. Subs only cover from 20-100 hz, stock speakers usually only go to a very screechy sounding 5k, while components will sound smooth from 100 to 16-20+khz, usually with more dynamic midbass and everything above is miles ahead.
