HELP; WIRING 2ohm DUAL COIL SUB
Username: Addisty
UK
Post Number: 24
I'vo got the alpine MRP-M850 amp which pushes 800rms@2ohms and 500rms@4ohms and a vibe space 2ohm dual voice coil sub; i want to wire sub into the amp @ 2ohms to get the 800rms. Any help pls
Username: Kingandsons07
TEAM REVOLUTION Lincoln,NE
Post Number: 512
if you got one sub you can't wire it to 2ohms... you can wire it to 4ohms or 1ohm
Username: Addisty
UK
Post Number: 25
Thanks Quentin,i guess got to change it for the vibe space DVC 4ohms then i can wire it to 2ohms
Post Number: 513
bingo D4 & D1 can be wired up 2ohms for a single sub setup
