Unregistered guest | glasswolf, i already have 2 JL audio 12W3v2 ( http://www.woofersetc.com/product.asp?0=314&1=318&3=1474 ) i have a '98 acura integra ls with factory alternator. I also have alpine CDA-9827 ( http://www.woofersetc.com/product.asp?0=204&1=207&3=1801 ) Would i be able to run the subs off a Rockford Fosgate Punch 801s ( http://www.boostcaraudio.com/index.asp?PageAction=VIEWPROD&ProdID=1871 ) it gives 400W x 2 at 2ohms. If i wired the subs parallel would this be too much? if not what do you recommend. i have a budget of about 350$ thx |
Silver Member Username: Its_bacon12Hfl, Ny Usa Post Number: 745 Registered: Dec-03 | get dual 2 ohm and i would not put more power on those JL's than they handle cuz they dont have warranty bp600.1 or kx600.1 would be excellent choices for those subs |
Unregistered guest | even though those last two mentioned are mono amps, how would i go about dividing the power between the subs? |
