Pre-amp vs Sub-out
Username: Carlo
Dublin, Dublin Ireland
Hi I have a Sony Crx-m800 head unit, an Alpine Amp, Alpine type r Sub. The Head unit has 2 pre-amp out puts and 1 sub out , which one should I use the pre-amp, sub out outputs.
Username: Jonathan_f
GA USA
Post Number: 417
Use the sub out. You can adjust the sub level, etc. and the voltage will be the same (or should, anyway).
