New member Username: Isai013Post Number: 1 Registered: Apr-09 | what's going on? I just a new car and im having a difficult time getting started. first of all I don't have much money, I like a lot of bass with a good quality sound to it. I don't want something expensive but don't want something that will break in a month. any suggestion will be very helpful thx. |
Gold Member Username: Snowball123West Allis, WI Post Number: 2569 Registered: Oct-07 | what's your final budget. you need need everything? HU, Amp, Sub, Wiring, or do you have any of this already. |
New member Username: Isai013Post Number: 2 Registered: Apr-09 | yea I need everything.. I went to see at this audio place and there were charging 400 with installation. it was two 12 mtx subs and amp. is that a good deal? |
Gold Member Username: Loc_outTeam RE XXX Post Number: 2807 Registered: Feb-05 | What type of car is it going in? what's your budget? |
New member Username: Isai013Post Number: 3 Registered: Apr-09 | its a 09 impala so I have a lot of room in the trunk my budget im not to sure but around 500 is wat im looking to spend. |
Platinum Member Username: Rovin1 15 = 149.5 DBs ...Trinidad & T... Post Number: 14836 Registered: Jul-05 | for 500 i see 2 options after u get ur HU & wires buy a 4 chan amp to play the whole set = a pair of speakers upfront & usually a 1 12" 300wrms sub on chan 3&4 OR buy a bass amp with a sub & listen to ur stocks speakers & then upgrade ur speakers & add a mids\highs amp alter on either option u shud build the box urself to save some $ ... |
New member Username: Isai013Post Number: 4 Registered: Apr-09 | the speakers in the car are actually pretty good. so what kind of subs and amp. should I go with the mtx is that a good quality brand? like I said I like a lot of bass but I want it to be good quality. |
Gold Member Username: Loc_outTeam RE XXX Post Number: 2808 Registered: Feb-05 | If you plan on keep the stock speaker. I'd go with something around 600-1000Rms |
New member Username: Isai013Post Number: 5 Registered: Apr-09 | I was thinking of that at least for now. but no one has any suggestion on what type of subs to get I don't know much about what are good brands so I don't want to buy something that might break in a month. |
Bronze Member Username: Mpinto19kDallas/Fort Hood, Tx Post Number: 52 Registered: Feb-09 | https://www.ecoustics.com/electronics/products/articles/329117.html You can use this to help. I'm still fairly new to car audio and I went with RD Audio subs. You can talk to one of those guys directly if you were to go that way. Good customer service. Other than that I was recomended these brands, just a few but may be a start: Fi RD Audio RE JL Just check some out and match it to your budget. |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 220 Registered: Dec-08 | ^ + Digital Designs (DD) |
Gold Member Username: Loc_outTeam RE XXX Post Number: 2809 Registered: Feb-05 | I would say a RE SE or SX. FI SSID or Q. |
New member Username: Isai013Post Number: 6 Registered: Apr-09 | cool u guyshave been very helpful thx for everything. I have one last question. what kind of head unit works best? I use to have an alpine and it never game me any trouble. should I go with another alpine? what do u guys recommend? |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 221 Registered: Dec-08 | good HUs: Alpine Clarion ProAudio Eclipse JVC Arsenal Pioneer Premier |
