I have nFusion Digital Satellite Receiver .. My problem is I can't view hindi channels on it except for Sony Sab .. I use 118.8 ANIKF3 My LNB Type is Standard ... If more information is needed plz ask..
Well Nalin, if you are so brilliant!!!!, instead of making this a battle field, wouldn't it be better to give some more information so everyone can use? You might be right that some channels aren't working, but in my case, more than %50 are down which means there is another problem, and Plymouth might be right it could be from my antenna.
As I said earlier, it would be easier to reply if there was more information. Anik F3 is a special sat requiring larger dish and special LNB and yet you can get some channels with regular or standard LNB. I do not feel I can start a whole session on all aspects surrounding Anik F3. So post your information and somebody will be able to answer.
Thanks Nalin. The thing is that I have the special LNB and 30" dish. I think this is all the requirments. Yet more than %50 of the channels are dark only for this sat. the rest( 119, and 110, and 121) are working fine.
Use separate slate - Anik F3 if there otherwise Anik F2 or ANY OTHER UNUSED SLATE. LNB freq 10750 or less. LNB TYPE: Universal 2 or standard First TP 11715 (V) Add all TPs from Lyngsat site. Do scan all. If not successful, remove all TPs except the first and do a full scan. If not successful, try Blind scan. TPS are not necessary. However, you may get a mixture of Anik F3 and Echo 7 channels. For DisceqC setting, make sure you have the correct one - usually the same as used for Echo 7.
Yea I tried that but the same problem persists.I can only view one channel i.e.Sony Sab .. I can view other channels on 119 its just 118.8 which I can't watch.
Guys, i hope this post gives you some information. as of today 3/4/09 all international channels, like Indian,Pakistani,Chinese,Arabic etc have all been moved to n3 by dn this applies to the channels on 61.5,148 and 118 you will not be able to get these channels for quite some time to come,as n3 has not been hacked and will not be hacked for quite some time to come. so if you tune into an international channel and a message like "scrambled channel" or "waiting for updates " appears, that does not mean dn is down,but you are trying to receive and international channel which has been moved to n3
zagros: You are registered here since 2006 and the information you gave in your last two posts is about a month old. I have also posted similar information around that time.
You asked the forum: "Does anyone know why some channels of 118 are not working and is there a solution for it?"
You did not mention anything about what channels you are talking about and what dishes LNBs you have. I replied very directly that some channels are missing and some are there and you DID NO LIKE THE ANSWER!
I think you better get your head examined and next time you ask a question give all the relevant details of your system and what you are looking for.
