New member Username: PsopPost Number: 1 Registered: Mar-09 | Hi, I cant send upgrade from my pc port to the satelite box. Like there is no sign of connection between them I've tried all port on the loader. I got a Fortec Lifetime Ultra and connected it trought a rs232 wire to my com port on my desktop pc. Could you help me please Thanks |
Silver Member Username: Albino_midgetPost Number: 760 Registered: Jul-06 | Are you sure you are using the correct rs232 cable ? (there are two types , straight thru cable and a null cable, they look the same but are different) The fortec uses the straight thru cable. |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2625 Registered: Dec-06 | Female-to-female 9-pin straight through serial cable needed | |
Gold Member Username: GregrafPost Number: 2565 Registered: Dec-07 | I love it when you talk dirty Doreen | |
Gold Member Username: PlymouthCanada Post Number: 8481 Registered: Jan-08 | LOL | |
New member Username: PsopPost Number: 2 Registered: Mar-09 | How can I know if I got the good type of rs232 cable ? | |
Gold Member Username: DimwittPost Number: 1212 Registered: Aug-06 | ||
Gold Member Username: DoreenakadjOntario Canada Post Number: 2626 Registered: Dec-06 | ||
Silver Member Username: Jaye50Post Number: 161 Registered: Aug-07 | i had the same problem with connecting from my laptop.....discovered that i had infrared enabled and it was using com 1....once i disabled infrared in the bios there was no problem.....first thing i'd do is make sure that there is no conflict on com 1...... | |
New member Username: PsopPost Number: 3 Registered: Mar-09 | what was the thing that you disable in bios? | |
Bronze Member Username: Mike_mPost Number: 52 Registered: Mar-06 | i,m on a pansat3500 using com 3 with my new usb cable it starts to download yet it stops on 0 it been sevaral hours what am i doing wrong please help when i use the other coms it says it dosent read serial port | |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2640 Registered: Dec-06 |
try this |
