Help with Viewsat Xtreme.
Username: Vicsalas
Post Number: 11
Greetings...
I have a Viewsat Xtreme, I had a lot of duplicate channels so I decided to erase them all, and make a blind scan, but now i lost a lot of channels including, 9000s, PPV, XXX and many more, what can I do?...Another thing, quality's gone way down ever since I uploaded the last 4 bins maybe.
Username: Plymouth
Post Number: 8490
Victor Salas
Check the antenna settings the LNB Type is probably not right.
since the last 4 bins Dn add many channels in N3 and all the channels are more compressed, that's why your quality is goes down.
For delete channels you must use Channels organization.
Username: Vicsalas
Post Number: 12
Plymouth, thanks for your quick response, my settings are:
Sat: Echostar 7 119.0W
LNB Power On.
LNB Type OCS-DP
LNB Freq. 11250
22KHz Off
TP Freq. 12370
Diseqc 1.0 None
Motor Off.
Legacy SW None.
I already did what you recommend on other posts: factory default, factory bin, sat info and new bin, did a rescan and got 58 channels :'(
Please help.
Username: Plymouth
Post Number: 8493
Victor
Try to set the LNB Type on standard and do a autoscan.
