Completely black screen opon opening pc
Username: Grampsny
I have a gateway laptop. When opening it last night I had only a black screen with a flashing cursor in the upper left corner. I had 2 choices; Bios or F10. I got to both of them but couldn't get windows started. Kept going back to aforementioned screen.
I have IE8 - XP32 - SP3
THIS IS NOT A BAD BULB.
Help, Please.
Username: Grampsny
Re: Above problem
I tried removing the battery and holding down START button for 2 minutes. It didn't work.
Username: Dntpay4sht
Does it boot at all? How old is it?
Need to Register?
Forgot Password?
Enable HTML code in message
