Username: Statboy Post Number: 83 Registered: Aug-07
Saturday, March 28, 2009 - 22:07 GMT I have loaded the new BIN 211 on my orginal Pansat but I keep getting scrambled or bad channel, what can I do to fix this?
Username: Nydas Post Number: 14725 Registered: Jun-06
Saturday, March 28, 2009 - 22:15 GMT 1. Hard reset. 2. Load again. 3. as soon as you get into the receiver do 8282 and "set default keys.
Username: Statboy Post Number: 84 Registered: Aug-07
Saturday, March 28, 2009 - 22:21 GMT How do you do a hard reset and also what do you mean by 8282 and set default keys? Can you please give me an example?
Username: Dimwitt Post Number: 1207 Registered: Aug-06
Saturday, March 28, 2009 - 23:09 GMT Hard reset = off/on via switch on back of receiver 8282 - while on a channel enter 8282 and it will take into the menu, you select 'set default key' , exit out of menu and wait on a channel for the keys to autoroll
Username: Riconissan Post Number: 605 Registered: Feb-09
Saturday, March 28, 2009 - 23:19 GMT Sounds like a lot of work. with my 4 (Four) Viewsats I just load the bin. and enjoy TV.
