Blow Through Truck Need Help
Username: Dangeranger
Ohio United States
Post Number: 13
My buddy is doing a blow through in 1978 F150 Single Cab. Using 3 Power Acoustik Mofo 12s ported 1 at 40 Hz and the other 2 at 32 hz. the amps are Hifonics Brutus BXI1600 and Power Acoustik A3000BD. Any words of wisdom or advice?
He really needs to know any information on the seals. Thanks in advance.
Username: Basebalz13
Moneta, Va Usa
Post Number: 1225
eh why that equipment?
Username: Surferdude9371
Get loud or go home....
Post Number: 1766
use a plasma cutter if you have access to one, dont stick the box through into the cab, buy an "accordian seal" that inflates for a perfect fit between, get diff audio equipment if not already purchased.
Post Number: 1767
also dont port at diff freq
Ohio United States
Post Number: 14
What frequency would you guys recommend? He wants Spl as well as good sound quality.
Username: Rideredder
Cornell, IL USA
Post Number: 1579
Don't mix frequencies or amps. Just make them all in a common chamber box and tune it to a certain frequency through the cab.
