Gold Member Username: Killer44Ontario Canada Post Number: 1013 Registered: Dec-04 | jsut showing the newish rims i jsut got the other day...they are giovanna ararat 22's...those are not the tires im going to keep on..ordered some 305/40/22 coopers yesterday should be here in 2 weeks or less...i bough them off a friend who rode them on his cadilac sts for 2 summers(thats why the tires are so small) ![]() ![]() |
Bronze Member Username: Caesar1212Brandon, Fl Post Number: 40 Registered: Feb-09 | honestly i dont like the look of it they look too small for your car maybe that will change w/ the change of tires |
Gold Member Username: Killer44Ontario Canada Post Number: 1014 Registered: Dec-04 | the look will definetely change with the new tires they are much bigger and 22's are the biggest recommended for explorers some fit 24's with very low profile tires...it will look like this picture this guy has the same tires im getting with 22's...http://www.cardomain.com/ride/3044194 |
Silver Member Username: SemperfiPost Number: 195 Registered: Oct-08 | killer once you get some new tires on there im sure it will look alot better than a caddi with those things on there... IMHO |
Gold Member Username: Killer44Ontario Canada Post Number: 1015 Registered: Dec-04 | thanks yeah i know it will...it will look exactly like the cardomain link i posted...he has the same tires and same model and year truck...jsut different rims |
Gold Member Username: Skibum12189Cleveland Post Number: 3129 Registered: Mar-06 | that'll look sick, ride easy on the tires until then, wouldn't want to crack/dent a rim, or bubble a tire. |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1444 Registered: Jun-07 | looks like crap with those tires. be sure to post pics when u get new tires! bet it will look good |
Gold Member Username: Basebalz13Moneta, Va Usa Post Number: 1208 Registered: Aug-07 | lower that btch!!!! |
Silver Member Username: Dsmith07NC Http://com4.... Post Number: 914 Registered: Jun-06 | looks funny like that but im sure it'll look 100% better with bigger tires |
Gold Member Username: RideredderCornell, IL USA Post Number: 1575 Registered: Sep-05 | Are the rear rims smaller than the fronts? |
Gold Member Username: Killer44Ontario Canada Post Number: 1016 Registered: Dec-04 | cal- i took them off until i get the new tires i only tried them on to see if they fit and if i liked them mark- the rims are both 22 x9.5 ill be sure to post pics with the new tires and also the new subbox and the rest of my setup since ive never posted it on here |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1448 Registered: Jun-07 | wish i could have rims..... to bad i work at walmart |
Gold Member Username: Snowball123West Allis, WI Post Number: 2504 Registered: Oct-07 | buy some rims from walmart. |
Gold Member Username: Big_edge_headMilwaukee, WI Post Number: 3598 Registered: Mar-07 | Lol get some plastic spinners blk |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2465 Registered: May-07 | Plastic spinners add dbz! |
