New member Username: TdwpgtpCleveland, Ohio Post Number: 6 Registered: Mar-09 | hey everyone. i was wondering if anyone knew what a good choice for a sub would be for a 1973 MGb convertible. its going to need to be a pretty low power setup because of the stock alternator, and the sub will have to be in the cabin because the trunk is separated by steel sheet metal, and we are not going to cut it. would sealed or ported be better, and any specific subs you could recommend. going for SQ by the way |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2822 Registered: May-07 | budget? UL critical Mass 12" sealed? |
New member Username: TdwpgtpCleveland, Ohio Post Number: 7 Registered: Mar-09 | LOW POWERRR haha. no way that lil car could supply that much power. im tryin to keep the sub around 100 bucks. it doesnt need to be amazing just some bass backup, since all the bass from the doors is lost with the roof down. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2824 Registered: May-07 | sorry was a bad attempt at a worse joke. I have never and wouldn't recommend a UL due to the fact that I have no expreience with them. http://www.etronics.com/p-14017-infinity-kappa-perfect-101d-10-dual-voice-coil-s ubwoofer.aspx?dp=F2C2D2A2E6322253D38363C3B3571373637373131313 |
New member Username: TdwpgtpCleveland, Ohio Post Number: 8 Registered: Mar-09 | haha alright i wasnt sure if u read my post right or not. |
Gold Member Username: TejcurrentPost Number: 1777 Registered: Apr-07 | I'm not sure on what your interior looks like, this is your car right? ![]() |
New member Username: TdwpgtpCleveland, Ohio Post Number: 9 Registered: Mar-09 | haha ya minus the tacky gold and purple and the fat black chick haha |
