Bronze Member Username: Will4992NC Post Number: 61 Registered: Mar-08 | I am looking to put a 10 inch sub in my car. I am looking for great sq while still retaining some good spl. I have found an FI Q, IDmax, Brahma, and a revo for around the same price. I have 1000rms to work with. What would you choose? |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1745 Registered: Mar-07 | id do the Q or idmax |
Bronze Member Username: Will4992NC Post Number: 62 Registered: Mar-08 | forgot to say its gonna be in a sealed enclosure. |
Silver Member Username: SemperfiPost Number: 190 Registered: Oct-08 | i have an IDmax and i LOVE it... its powered by an AQ1200D |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2458 Registered: May-07 | Will- What amp are you going to be using? What version Brahma did you find? |
Bronze Member Username: Will4992NC Post Number: 63 Registered: Mar-08 | The amp is a JBL gto14001. The brahma is a MKII with an hc motor. http://www.caraudio.com/forum/showthread.php?t=381198 I don't know much about the brahma, but have heard it is a good sub. |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 7361 Registered: Mar-04 | If the "brahma" has an RE HC motor, then it is NOT a Brahma. Its just a reconed RE HC. The MKII Brahmas had XBL^2 motors. That design is TOTALLY different than the HC motors. It will not sound like a real brahma. May still sound nice...prolly underhung recone, but still not a Brahma. |
Gold Member Username: Mike11202RE MT 15 VFL 200.1 , Sewell, NJ US Post Number: 1881 Registered: Nov-06 | Revo or IDMax |
