Gold Member Username: Skibum12189Cleveland Post Number: 3112 Registered: Mar-06 | I had my heart set on a Nine.2x and a Nine.1 for 2 12s and my diamond s600's my s600's need about 150+ rms at 4 ohms the 12s will need about 1300-1400 rms at 1 ohm I know some might not appreciate this, but I want my amps to match, that's why I was thinking ED amps initially, but I'm open to anything. figure like 350-375 for the pair of amps shipped. I've got a jeep and I like having a clean looking setup. Was considering AQ amps, but will the multi-channel amp give my HEX's enough power? |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 7351 Registered: Mar-04 | Do you have 2 set of s600's? |
Gold Member Username: Skibum12189Cleveland Post Number: 3114 Registered: Mar-06 | nah, i only run a front stage. one set of HEX's, (only need a 2-channel amp or a bridged 4-channel) |
Gold Member Username: Mike11202RE MT 15 VFL 200.1 , Sewell, NJ US Post Number: 1870 Registered: Nov-06 | http://www.woofersetc.com/p6838/DSC480--MB-Quart-4-Ch-640-Watt-Amplifier.htm http://www.woofersetc.com/p6835/DSC10001--MB-Quart-1-Ch-1000-Watt-Amplifier.htm |
Gold Member Username: Skibum12189Cleveland Post Number: 3115 Registered: Mar-06 | those are nice, keep em coming though... whats the dsc10001 pushin? |
Gold Member Username: Mike11202RE MT 15 VFL 200.1 , Sewell, NJ US Post Number: 1871 Registered: Nov-06 | i would get that 4 ch. so bridged the comps get 320 a side, the hexs need alot of power the dsc10001 will do 1,000rms |
Gold Member Username: Skibum12189Cleveland Post Number: 3117 Registered: Mar-06 | yea they do, they're power hungry |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2798 Registered: May-07 | get the AQ1200. I may not match but it is a great amp and very inexpensive. It wouldn't hurt to run the AQ 4 channel.. The Hex's will get plenty loud on 90 wrms.. They are fairly efficient. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10156 Registered: Jul-06 | Bridge the AQ 4ch so you get lots of 2ch power. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2799 Registered: May-07 | that is what I was thinking^^^ 240 wrms x2 @ 4 ohms. will have to cut it way back, but it can work...You can try running them active un bridged -would be another option. |
Gold Member Username: Skibum12189Cleveland Post Number: 3118 Registered: Mar-06 | theaq 4 channel will give me 240x2@4??? sh!t, i musta misread, i think i'll defly go AQ now. they're high quality built amps right, not junk? My HEX's can take 175 easily, i'd give em 200 without hesitating, ill just adjust.... |
Gold Member Username: Skibum12189Cleveland Post Number: 3119 Registered: Mar-06 | do i order em through AQ or can someone on here hook me up? sorry, i've been outta the game for a bit |
Gold Member Username: BlainewPost Number: 2876 Registered: Nov-05 | i remember my first system |
Gold Member Username: Mike11202RE MT 15 VFL 200.1 , Sewell, NJ US Post Number: 1873 Registered: Nov-06 | http://www.audioque.com/aq/order.htm their 4ch is 229 and mono is 249 the hexs need alot power to get moving thats why i suggested the mb quart 320rms x 2 @4ohm bridged.. the the local shop near me has them plus youll have the headroom with an amp that powerful |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2801 Registered: May-07 | MB Quarts = Maxxsonics = mehhh |
Gold Member Username: Snowball123West Allis, WI Post Number: 2491 Registered: Oct-07 | RD Audio = mehhh |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2449 Registered: May-07 | RD>maxxsonics My AQ1200D is still kickin' strong, great amp for the money. I remember hearing allot of good things about older MB quarts stuff (the RAA 1000 to be exact), but not so much about their new stuff. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2803 Registered: May-07 | Hatin' is a b!tch.. you know better..You know that I know you know better. deny if ya want. |
Gold Member Username: Mike11202RE MT 15 VFL 200.1 , Sewell, NJ US Post Number: 1874 Registered: Nov-06 | the new mbquart products look pretty impressive, you can't judge because its maxxsonics, they have very flexable crossovers and looks like they're using quality parts from what i see on the outside i ordered a 4ch today, ill see what it looks like inside when it gets here |
