Gold Member Username: Skibum12189Cleveland Post Number: 3124 Registered: Mar-06 | Debating mounting my subs inverted and firing down in a sealed box for my next set up. How would it negatively affect the SQ/SPL. I don't need to have it ridiculously loud, but would it be like super quiet? |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20095 Registered: Jun-06 | Makes no difference on the output of the sub. I did it with my mag, in a ported box though. Worked. Well. |
Gold Member Username: Skibum12189Cleveland Post Number: 3125 Registered: Mar-06 | What about if it's downfiring? I would build the box and my trunk so the undersides of the subs are visible....purely bc i think it would look sick. one time, i took my old 12s and faced them towards the roof instead of the trunk (in a jeep cherokee) and i felt like they got a little quieter. was i imagining things or is there truth in that? bc currently, my TC3K 15 is facing the roof (ported) and it absolutely killlllls. |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20096 Registered: Jun-06 | http://www.glasswolf.net/papers/inverted.html |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20097 Registered: Jun-06 | It may look odd but this 15" mag was inverted and powered by 1000w used in my HT. It rocked. So much it destroyed the plexi enclosure I built around it to protect it from dust. Fun while it lasted. ![]() ![]() |
Gold Member Username: Skibum12189Cleveland Post Number: 3126 Registered: Mar-06 | would i have a problem with dust do you think? |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20098 Registered: Jun-06 | I wouldn't think. I just did that because it was indoors. I didn't want anything accumulating on the cone discoloring it. Plus I have young kids. Shiny and/or moving parts are a playground for young children lol. Oh god have I endured many pushed in tweeter domes in my past. |
