MY AMP WORKS WITHOUT REMOTE WIRE AND WONT TURN OFF WHEN IT IS HOOKE UP PROPERLY....HELP PLEASE!!
Username: Branddon2008
I have my system hooked up and it works fine but the amp wont turn off and in turn overheats and makes my battery die when left over night. I was thinking about getting a switch for my Remote wire but 1. I dont know where to put the pore wire for the led switch 2. Idk where to hook up my remote wire seeing as how it doesnt work when hooked up to blue and white remote turn on wire on post factory HU. Any suggestions??
Also i was wondering does any 18 guage or any guage wire work for the remote wire? And can you spit it off to 2 amps or is the resistance too high?
Thanks and sry for the long post as you probally see im a newbie lol
Thanx for the help!!
