i have 2 memphis mojo 15q and i want to hook them up to a memphis mojo 4k amp and i was woundering if anybody can help me with a diagram or something to help me with the install thank u
They are quad VC right?If they are then you can't do it. the mojo quad VC is a quad 1 ohm sub, which you wire in a series/parallel to get 1 ohm. Then you do the same with the other sub.You wire them in series to get 2 ohms... or parallel nd get 1/2 ohm...but no way for 1 ohm.
I would not recommend running the Memphis 4000D at .5 ohm... Now would be a good time to sell it and get a better amp( one that is more efficient) The RD3250 can be run at .5 ohm daily if you have the charging system for it. Just an idea.
