Silver Member Username: Armykyle1Ms Us Post Number: 490 Registered: Dec-08 | i got $330 in bestbuy gift cards, what should i get? I need everything for my car but a HU. Throw some ideas at me guys. |
Gold Member Username: Loc_outTeam RE XXX Post Number: 2760 Registered: Feb-05 | Try to sell them last time i went there i didnt see anything good. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2755 Registered: May-07 | All you need to mdo is go into Best Buy and ask one of their car audio professionals what you should get to have a killer system. They are "known" for their great service, selection, and knowledge. just so you know, I was being sarcastic. They are a terrible place to have anything done, and the equipment that is decent is WAYYYYYYYYYY over priced. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2756 Registered: May-07 | get something for your computer, navigation, or gaming. |
Silver Member Username: WickedbassNashville, Tn Post Number: 444 Registered: Jan-08 | How about some dynamat? I think they sell it a BB, its been a while since I've been there. |
Platinum Member Username: Rovin1 15 = 149.5 DBs ...Trinidad & T... Post Number: 14772 Registered: Jul-05 | im sure u can get something decent like alpine comps\subs ... |
Gold Member Username: ShortysetniesAndrew Capps, NC US Post Number: 3268 Registered: Mar-06 | sell it. I got $45 for it :-) |
Gold Member Username: Loc_outTeam RE XXX Post Number: 2762 Registered: Feb-05 | They do sell dynamat 100 per sheet or something like that. Get a PS3. |
Bronze Member Username: ChristopherrmPost Number: 51 Registered: Nov-05 | Yeah the dynamat is like 100 per coupe door kit (12 sq ft I believe) there so it isn't worth it. |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20057 Registered: Jun-06 | Buy me something.![]() |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10076 Registered: Jul-06 | I think best buy does sell alpine IIRC. And Alpine is one of the few brands where you can by ALL your equipment from that brand and come out with a good system. So that makes it easy haha. |
Silver Member Username: Armykyle1Ms Us Post Number: 491 Registered: Dec-08 | I'd get gamin stuff but since I have no use my left hand still itd be pointless lol. I have some some RF comps up front right now so I could get some rear fills or a 2ch or 4ch amp. I can get stuff online too. I have all the computer stuff I need too. Got surround sound and all that. Got badass head phones too. Ill see wat the got in store tomorrow and post some ideas |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2759 Registered: May-07 | Get a 2nd monitor, By far one of the best computer upgrades you can do as far as price, productivity, ease of use, and bang for the buck. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10081 Registered: Jul-06 | Then don't forget a second video card so you can use your 2nd monitor. |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2760 Registered: May-07 | if it a desktop and using intergrated graphics, then he will likely need a video card, but a laptop can usually get by w/o one if he don't mind using the s-video output (if equiped) |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10086 Registered: Jul-06 | Two problems.... usually that output shares the video on the first display and is not independent, altough not always the case. And the resolution of S-video sucks. Standard def TV. Nowhere near suitable for a monitor, which use even higher resolution than HDTV. |
Silver Member Username: Armykyle1Ms Us Post Number: 492 Registered: Dec-08 | i have a laptop, its got DVI and Svideo out, My laptop has a 17" screen so it does good. When i was at best buy today, the only car audio stuff i saw that i would consider was this infinity amp for like 150 and some Type R comps, and I'll put use the tweets it comes with up front instead of the RF tweets. http://www.infinitysystems.com/car/products/product_detail.aspx?prod=REF475A&cat =AMP&ser=REF&Language=ENG&Country=US&Region=USA also this alpine amp http://www.bestbuy.com/site/olspage.jsp?skuId=8699349&type=product&id=1199494646 190 any other ideas guys? |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2764 Registered: May-07 | I would seriously get another monitor, especially if you have a DVI output. It is not how big your 1st monitor is, it is what you can do with 2 monitors. I run 4 monitors, very convient plus the "wow factor" doesn't hurt either. lol Once you start running 2 monitors, you will miss it when not at your computer, trust me. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10088 Registered: Jul-06 | With a DVI out it will work. Running 2 monitors that is, independently. |
Silver Member Username: Armykyle1Ms Us Post Number: 494 Registered: Dec-08 | I got a iPOD touch 16gig, its pretty cool, thanks guy, sorry for the slow response, i was out... |
