Wiring gauge question
Username: Squatch1009
Post Number: 12
I just got my AQ1200D in today and I was reading the manual and it said to use 0 gauge wiring to power it. I have 4 gauge in my car right now, is 4 gauge gunna give it enough power to work to its potential? I have an 02 Ford Mustang by the way, not exactly sure what kind of alternator I have though.
Username: Vivi2000
Owosso, Mi
Post Number: 140
4 would be the minimum I would use for that amp. If you have the 4 now use it and see If your voltage is ok. If not buy 0awg and use that.
Username: Bonhamd
Traverse City, MI
Post Number: 1787
4 guage will work fine but it helps to have 1/0
http://bcae1.com/
scroll down to #16 - thats a good site to read in general
Diamond Member
Www.stainles... .ecrater.com
Post Number: 20046
"I have 4 gauge in my car right now, is 4 gauge gunna give it enough power to work to its potential?"
It's not about giving power, it's about delivering it safely. You want a gauge wire that won't heat up excessively because of the small size. Even a small wire will deliver a large current briefly before it fails. Kinda like a fuse. You DON'T want to size your wire like a fuse lol. Bigger is better baby.
Post Number: 13
thanks alot, ill try it out with 4 and see what happens
Username: Dsmith07
NC Http://com4....
Post Number: 893
i'd always use 0 gauge just in case for future upgrades with more power
