Stupid stupid noob mistake help quick!!!!
Username: Mj23dynasty
Alpine ida-x001/2 dd 2..., Woodlawn Por... USA
Post Number: 2003
Stupid stupid mistake I made... I forgot to disconect the batter b4 I put my 300a fuse back in the fuse holder (in line fuse) and I got a bunch of sparks and the thing d@mn near melted I feel like such a dumb @ss ... so I was wondering do u think I jus blew the fuse or did I blow my nice saz also.... I wasn't thinking I was in a rush on break @ work I'm working now so I can't go get another fuse to see if the amps gone too... I jus need peace of mind for now.... I'm p1ssed!
Username: Deadrabit
Marionville, MO
Post Number: 1376
everything is shot
Username: Turnmat
Racine, Wi
Post Number: 927
I dont think everything is shot. Hard to say until you get another fuse though. How are the fuses an your saz? check them if you get a chance
Username: Surferdude9371
Get loud or go home....
Post Number: 1714
i bet your amp is fine
Username: Basssquared
Kansas
Post Number: 2493
X2
Post Number: 2004
um got another inline fuse but no power to amp checked with mult meter its getting enuf juice but nothing... checked fuses on saz and all r blown havent got a chance to get any more yet but do you think once i get new fuses it will work? and once i get the fuses do i need to disconect the battery b4 putting them n?
if it is blown u think i should get a new amp or repair this one?? im so mad @ myself u wudnt believe...
Username: Snowball123
West Allis, WI
Post Number: 2417
lol.
Diamond Member
Www.stainles... .ecrater.com
Post Number: 20034
Fuses blow to protect your stuff. Odds are it's fine.
Not betting odds though.
Username: Loc_out
Team RE XXX
Post Number: 2751
I say your amp is fine, replace the fuses and let us know.
Username: M0nstar
Toledo, OH U.S.
Post Number: 183
x3.
fuses are probably the best invention as far as electronics/ circuitry go. i say replace all fuses, and YES when you're doing it disconnect your batt. why would you ask that? look what just happened when you DIDNT disconnect it!?!
Post Number: 2005
Lol I'm an idiot at this stuff hence the reason I never attempt intalls but I hate payin to get lil stuff done... I didn't think pluggin in fuses wud matter but ill disconect next time... soon as I get off work ima go grab some but thy don't sell jus 40 amps so I gota get like 4 packs of the multi packs I'm prayin it still works bcuz I don't got another 500 bucks for a new amp...
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2416
I'm confused... did you have wires crossed in the back or something??? You shouldn't have to disconnect the battery before you install a fuse.
Post Number: 2007
Yea thts what the car audio shop said what could it be? And ok so the amp is hooked up right now with in line fuse all wires r hooked up except rcas but the fuses on the amp aren't in the amp I got new fuses for the amp but what steps should I take with disconecting the power wire or disconecting the wires from the amp first b4 I plug them back in to see if I get power?
West Allis, WI
Post Number: 2426
dude it's hard to understand what you are trying to say. I'd say yeah just disconnect the negative post on the battery before you put the fuses on, takes what, 3 seconds.
Username: Riconissan
Post Number: 417
If the fuse blew while you were reinstalling it . Then there is a short to ground somewhere. Fuses do not blow for no reason.
Username: Turnmat
Racine, Wi
Post Number: 930
Just to be safe disconnect your batt and then install your fuses. Connect your rca's. After everything is connected then connect your batt and see if you have power.
Username: Van_man
Boston South, MA
Post Number: 4685
If the fuse blew while you were reinstalling it . Then there is a short to ground somewhere. Fuses do not blow for no reason."
^^^^this.
use a dmm set to read continuity. Put it on the pos wire at the amp. This wire should be disconnected from amp. Also do not have a fuse in yet. Now put one lead on the wire, the other on a ground. If theres continuity, replace/check the pos wire.
Post Number: 2008
What is a short to ground and how do I fix it? Bcuz the guy @ the car audio shop said it shudnt have blown also... so somethings wrong. I'm thinking about not even touching it and jus waiting till I get my comp amp installed to let them fix it....
Username: Van_man
Boston South, MA
Post Number: 4687
Post Number: 420
"what is a short to ground"
Your positive side needs to pass through resistance ex: a light bulb or in your case an amplifier before it completes the circuit back to ground. If the positive side of your battery finds a "shorter" path to ground it is a "short Circuit. Some where you have a bare wire touching ground (the car chassis) Or inside of your amplifier there has a short. My point is that for your 300 amp fuse to blow. something is very wrong.
Post Number: 2009
i dont have a dmm so what dou suggest? should i jus leave it alone and let a shop fool with it? i Have a pretty good shop around here thy r the best in the area thy kno more than most of the clueless shops around here.
Post Number: 425
Good idea brother. I wish I was there to help you.
Illinois Braaap MX
Post Number: 2418
Go to walmart (or any hardware store) and pick up a digital multimeter (dmm) for like $10.
Username: Mendonmafia
Post Number: 1747
lol i usually install the fuse last. its just such a pita to disconnect all my grounds, that i never do it. never had a problem yet and ive done it probably 50 times.
Post Number: 2010
ahh i brought her back to life the problem was the damn ground and power labels on the amp r placed very stupid so i mis read them and hooked power and ground up mismatched it was jus blown fuses everything is working again good at least i think lol...
Username: Loc_out
Team RE XXX
Post Number: 2758
Glad you figured it out. What amp are you using?
Post Number: 429
Good to hear JayZ4Prez
Username: Turnmat
Racine, Wi
Post Number: 958
Glad to hear everything is ok!
